AirheadDave Posted June 15, 2006 Share Posted June 15, 2006 I have a '95 Impreza AT and the AC clutch pulley bearing is screaming. I expect the pulley is going to the great used parts yard in the sky. Since I do not want to replace the compressor, does anyone know a source for just the bearing or the entire pulley assembly? Feel free to make off-list contact if you want. bambam6"at"earthlink"dot"net. Quote Link to comment Share on other sites More sharing options...
nipper Posted June 16, 2006 Share Posted June 16, 2006 I have a '95 Impreza AT and the AC clutch pulley bearing is screaming. I expect the pulley is going to the great used parts yard in the sky. Since I do not want to replace the compressor, does anyone know a source for just the bearing or the entire pulley assembly? Feel free to make off-list contact if you want. bambam6"at"earthlink"dot"net. there was a link on here not too long ago about that same thing. You just replace the bearing (hopefully). Sadly it may be compressor that is making the death wale. Do a search and you should be able to find it. nipper Quote Link to comment Share on other sites More sharing options...
Subaru_for_LIfe Posted June 16, 2006 Share Posted June 16, 2006 I'm sure you could order almost any size bearing from many reputable bearing outlets. But the usual practice is to replace the entire clutch assembly. Many of the auto parts stores carry them. Quote Link to comment Share on other sites More sharing options...
AirheadDave Posted June 16, 2006 Author Share Posted June 16, 2006 I have been unable to locate a clutch rump roast'y by itself. Thanks for the heads up. I will try again Quote Link to comment Share on other sites More sharing options...
nipper Posted June 16, 2006 Share Posted June 16, 2006 Eurika http://www.ultimatesubaru.org/forum/showthread.php?t=58635&highlight=ac+pully nipper Quote Link to comment Share on other sites More sharing options...
AirheadDave Posted June 16, 2006 Author Share Posted June 16, 2006 nipper- you walk with the Suby Gods! Thanks. That thread did not show up on my searches Quote Link to comment Share on other sites More sharing options...
nipper Posted June 16, 2006 Share Posted June 16, 2006 nipper- you walk with the Suby Gods! Thanks. That thread did not show up on my searches i tried AC pulley:banana: that and i still have no life and im pigheaded:grin: nipper Quote Link to comment Share on other sites More sharing options...
