flit Posted June 26, 2006 Share Posted June 26, 2006 So, i'm having this strange problem with my Outback, where if i drive the thing for less than 15 minutes, it won't start again. I thought it was the ignition coil, but when i replaced that, it seemed to work for about a week, and then the problem started again. It doesn't do it every time, just enough to be annoying. If i drive it for longer than 15 minutes, it doesn't do it. Any ideas folks? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 26, 2006 Share Posted June 26, 2006 never have a CEL light? mileage on the car? any recent maintenance done? when were the plugs/wires replaced last? are they Subaru OEM or aftermarket wires? Quote Link to comment Share on other sites More sharing options...
flit Posted June 26, 2006 Author Share Posted June 26, 2006 the check engine light comes on immediately after not starting, but goes away after a few clean restarts. The CEL diagnostic says cylinder misfire (cylinder 2 if i remember right), 130,000 miles on the car, replaced the spark plugs and wires when i bought it a year and a half ago, and they are aftermarket wires.... any other things i left out? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 26, 2006 Share Posted June 26, 2006 ding ding ding...just as i suspected. get Subaru OEM wires. (or magnecor, that's what i use). anything else is susceptible to exactly what you're describing. the 2.2 and 2.5 engine layout is not very forgiving, the wires need to be high quality on these motors. Quote Link to comment Share on other sites More sharing options...
flit Posted June 26, 2006 Author Share Posted June 26, 2006 Thank you for the info. IT's good to finally get an answer after asking practically everyone in the world. Quote Link to comment Share on other sites More sharing options...
Sweden Posted June 29, 2006 Share Posted June 29, 2006 flit, Is the starting problem fixed? I had a similar problem last year with my '96 OBW-EJ22. Are you getting a check engine light? If so, try and pull the code. My problem ended up being a faúlty crankshaft angle sensor (CAS), the $60 one. I first had a bad Cam Angle Sensor, though so I wouldn't rule that out either. You can check what the problem is by having an extra wire and plug handy after it doesn't start. Plug it in and see if you have any spark. If not, it is likely there is not a signal to the computer to send out spark. Search for a past thread of mine on the subject of not starting. Good Luck! Sweden Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 29, 2006 Share Posted June 29, 2006 good call sweden, crank and cam sensors are good for doing that as well...forgot about those. but i think "cylinder misfire" codes are normally ignition wire related. Quote Link to comment Share on other sites More sharing options...
Sweden Posted June 29, 2006 Share Posted June 29, 2006 You are right with the code (sorry, I didn't read the whole thread close enough). One thing that was up with mine was that it didn't reveal the Crank Angle Sensor code for a number of days & trials at the mechanic. We got the Cam Angle Sensor code though; the problem was that I had just replaced it a few days earlier. My car is possessed Sweden Quote Link to comment Share on other sites More sharing options...
nipper Posted June 29, 2006 Share Posted June 29, 2006 Well this is an electronic problem of some sort. If you can make it happen on command do it, then check the cam angle crank angle sensors and the engine temp sensor. Also check output at the ignitor. Can be any one of those. If you have injectors working buy no spark it may be the ignitor. nipper Quote Link to comment Share on other sites More sharing options...
flit Posted June 30, 2006 Author Share Posted June 30, 2006 Thanks for all your help guys, lucky for me i'm short on money this week, so i haven't tried any of your suggs, but i'll let you know what works. Quote Link to comment Share on other sites More sharing options...
