rlsimpso Posted July 18, 2006 Share Posted July 18, 2006 1986 BRAT 1800 GL 4 speed D/R, without the rear seats from the factory How acurate of the oil pressure guage? On the highway at 65-75 it reads almost all the way up, about 75. It has been like that since I got it last summer. I guage does go up and down with engine speed. It doesn't seem to change with 30 or 40 weight oil either. Is this normal, or should I be doing something about it? I am considering getting another subaru of this vintage due to the problems I've had with me Legacy. The EA engines seem to be much better then the EJ series. Quote Link to comment Share on other sites More sharing options...
Bill90Loyale Posted July 19, 2006 Share Posted July 19, 2006 Check out this thread. Particularly the final post. Archemitis is one of the gurus. http://www.ultimatesubaru.org/forum/showthread.php?t=20242&highlight=high+oil+pressure Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 20, 2006 Share Posted July 20, 2006 It's just your sender, and your guage. Probably not all that accurate. A brand new EA81 will usually peg the guage out, but most that I have seen run at around 45-60 at hot cruise. It's the hot idle reading that matters most - should be no less than 20. Higher is ok, but once they are broken in, they generally will not peg the guage out like that unless there is some electrical issue in the guage or the sender. The senders like to fail, and they like to be different as they age. In fact I doubt any of them came very calibrated anyway. I've replaced senders and gained nothing, and other times I've done it and gained 5 to 10 pounds. You have to understand tho that the pressure reading is AT the pump. If there are restrictions somewhere in the system (sludge, contaminates, bits of filter), your reading will be high. GD Quote Link to comment Share on other sites More sharing options...
rlsimpso Posted July 21, 2006 Author Share Posted July 21, 2006 Thanks for the info. That puts my mind at ease. I really need to learn how to search better:) Quote Link to comment Share on other sites More sharing options...
