tcspeer Posted August 4, 2006 Share Posted August 4, 2006 My neighbor, has a 1988 Justy and it has been sitting down on the ground for a while, with the axle gone and hub stripped out he wanted me to help fix it, after looking at it I see it is nothing like the 97 & 98 Legacy wagons which I have changed out the axles more than once. What I need to know does the axle go in the same as the legacy wagons and is it held by a pin also. The other thing is I see no threads on the holes in the spindle where the caliper bolts on. They may just be stripped out or maybe they are held on with a bolt that goes through with a nut on the other side. Any thoughts would be welcome. Quote Link to comment Share on other sites More sharing options...
RONAN Posted August 4, 2006 Share Posted August 4, 2006 The halfshaft is mounted on a splined shaft coming out of the transaxle. It`s held by a pin. The other end of the halfshaft spindle goes through the bearing housing and splined hub and is held by a bevel washer and castlenut. PM me is you need anymore assistance. I just changed my entire front from transaxle out... Quote Link to comment Share on other sites More sharing options...
