September 17, 200619 yr Greetings, I was wondering if there was a way of resetting the CEL without disconnecting the battery or using a scanner. (I don't want to disconnect the battery b/c I have an aftermarket keyless entry that's a PAIN to configure.) I've been looking for a fuse which supplies the ECM backup and can't find anything. TIA, Nathan EDIT: It's a '98 Legacy Outback
September 17, 200619 yr Author Power your keyless entry system separately, then disconnect the battery. Well, I got impatient and decided to just disconnect the battery. Turns out the keyless entry system holds its programming with the battery disconnected, CEL is off now, it's all good. Plan "B" was to unplug the actual ECM, but at that point, driving to Autozone starts seeming like a better idea. Nathan
September 17, 200619 yr Author try pulling the fuse to the ecu. nipper Nipper, In my first post, I mention trying to identify the backup fuse for the ECM. (OK, I called it an ECM instead of an ECU.) On the pain meds again? :)There's no fuse labeled as such. If anybody knows which fuse it is, please share! If nothing else, it'd be nice not to lose your radio presets when clearing the ECU.... Nathan
September 17, 200619 yr Nipper, In my first post, I mention trying to identify the backup fuse for the ECM. (OK, I called it an ECM instead of an ECU.) On the pain meds again? :)There's no fuse labeled as such. If anybody knows which fuse it is, please share! If nothing else, it'd be nice not to lose your radio presets when clearing the ECU.... Nathan no pain meds just not home right now. trust me i dread having to reset everything after pulling the battery cable. The ECU isnt in an easy place to just unplug it, but it may be easier then reprograming everything. There should be a fuse or two that kills it. If i rember correctly there are two power sources for the ecu, one always feeding it, the other powers it when the car is on. May be best to go to autzone nad have them clear it. And i would welcome pain meds today anyone got afew extra?:-p
September 17, 200619 yr Author Looking at my info it appears SBF-2 supplies continuous voltage to the ECU. That's located in the underhood fusebox, right? I'll try it next time (hopefully a long time!) the car throws a CEL. Cheers, Nathan
September 18, 200619 yr That's located in the underhood fusebox, right? I'll try it next time (hopefully a long time!) the car throws a CEL. Cheers, Nathan You are correct Nathan. It's in the box under the hood. I'm not sure what else it ties to but it may also go to the radio so the radio memory may a or may not be lost by pulling it. Glen
