beataru Posted September 17, 2006 Share Posted September 17, 2006 Hey guys I recently bought a Gl-10 and i was wondering if anyone knows about brake mods or suspension mods to make this little wagon a Little Fearsom road holder! even little things that anyone knows about would be appriciated. ive already got poly bushings everyware! Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted September 17, 2006 Share Posted September 17, 2006 Convert it to a 5-lug from an XT6. Larger swaybars, upgradable brakes, struts, and better wheel/tire selection. Check out the thread I have in the USRM about the swap. http://www.ultimatesubaru.org/forum/showthread.php?t=50400 Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 17, 2006 Share Posted September 17, 2006 KYB GR2's. I have a set front and rear. They're stiffer than stock struts. I am also using KYB GR2's from a 2WD XT for the front of my RX. They lower the front by about 2". Then look for springs from a RX which are stiffer than your GL10. THat will give you about an inch more clearance, dropping the front only about an inch or so. Makes my car handle like its on rails, expecially with the new 195/60R13's I am running. I could have went with 205/60R13 but that maybe too much tire for this little car. Also, XT6 sway bars are larger and a direct bolt in. I have not run any yet, but i might try to get some in the future. -Brian Quote Link to comment Share on other sites More sharing options...
beataru Posted September 17, 2006 Author Share Posted September 17, 2006 i Might do that a long time from now.... it has really nice 15 black pugs on it and i really really like them it has 205/50/r15 and it looks real mean! its got 4 wheel discs im wondering if anyone can fit a performace pad or rotors on them??? ps i just bought this car from rallyruss Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 17, 2006 Share Posted September 17, 2006 Oh damn, russ sold his wagon Well, hope its in good hands... dont beat that car up. I was running those rims on my RX when I did my suspension swap... and I had to go back to 13" rims cause those 15" rubbed after i dropped the front end. Here's a pic: Before: After: That was with stock XT springs though... after I installed RX springs, it raised the front alittle... might have solved the rubbing problem but by that time I had already installed 13" Rims. And here's a difference between the 2 springs. XT springs are on the left, RX springs on the right. -Brian Quote Link to comment Share on other sites More sharing options...
beataru Posted September 18, 2006 Author Share Posted September 18, 2006 wow small world in subarus... Ill take good care of it Anyone else got ideas its got performance coilovers in the rear from...I cant remember... but there preety stiff... anyways, im still ways out before i get anything so, keep the ideas coming.. I know you guys have done somthing to make one of these a beast! by the way is there a differance in springrates in the XT to the RX? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted September 18, 2006 Share Posted September 18, 2006 I have a set of cheap adjustable coilovers for a GC8 impreza (95-01 i believe) on my Loyale. they're 450/400 lb/in springs on the front and rear respectively. with an XT6 front sway bar (still no sway bar mounts yet in the back), and stock shocks. it handles SOOO well, even with the cheap M+S tires I have on it now. it's pretty bumpy, but real tight. if you're staying 4-lug, the best shock you can get is pretty much the GR2. But if you go 5-lug, you can use impreza/legacy fronts, and get KYB AGX's (adjustable!!). Watch this thread for info on fitting 2000-current legacy GT rear stuff to your EA82. here's what it looks like now: and yes, very small world here with the older subarus, most of us know exactly what car you're talking about when you say you've got russ's old wagon EDIT: found a pic of those springs. they're R-1 Racing brand, though I haven't been able to find any others like them.... stock impreza on the left, R-1 racing coilovers, JDM WRX STi ver. V (or VI, I don't remember) on the right: Quote Link to comment Share on other sites More sharing options...
beataru Posted September 19, 2006 Author Share Posted September 19, 2006 Hey i dont want to crowd the place wit another forum sooo i was wondering would i need to convert my car to a 5 lug to fit 2.5rs brakes or even STI Brakes to it? uh oh didnt get a response in less than ten minutes better make a new post lol yeah i figured as much Quote Link to comment Share on other sites More sharing options...
Hocrest Posted September 21, 2006 Share Posted September 21, 2006 Here's a pic: Before: Brian, what size tires are those? They didn't rub at stock height? Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 22, 2006 Share Posted September 22, 2006 205/50R15 i believe. And no, at stock height they didnt rub at all. -Brian Quote Link to comment Share on other sites More sharing options...
