jeep5.9litre Posted September 19, 2006 Share Posted September 19, 2006 On the way home, I noticed a sound coming from the wheels of my wagon, sounds like a loud squeaking sound..seems to go away at highway speeds, but slow its horrible..could it be the wheel bearings?? I also noticed that when the car is warming up when you push the gas pedal, it doesnt stumble..when its warmed up and running at normal RPM'S when you initially push the gas it stumbles a bit like it wants to stall out..replaced the plugs and still does it..any ideas? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 19, 2006 Share Posted September 19, 2006 Wheel bearings - probably. Stumble - either vacuum leak or carb needs rebuilding. GD Link to comment Share on other sites More sharing options...
75subie Posted September 19, 2006 Share Posted September 19, 2006 man, drive over with it and i`ll check it out:grin: but yea, the squeeling is most likely your wheel bearings. you should be able to jack it up and hear it. the stumble could be some junk stuck in your carb, or as gd said, a vacume leak. go WEBER and fix all those probs:brow: Link to comment Share on other sites More sharing options...
jeep5.9litre Posted September 19, 2006 Author Share Posted September 19, 2006 Well...im going to fix the bearings this week..once i get time then ill bring it on up to NY... hmm Weber eh?? Link to comment Share on other sites More sharing options...
