September 21, 200619 yr Anyone done this or on any other similarly tagged sube? ever seen one with it taken off/fell off ? Reason I ask is that I finally got in my WRX and turbo badge in and wanted to see if when I removed the single "subaru gl10" emblem on the back will there be holes? Or was it a simple adhesive like all new ones? Thanks
September 21, 200619 yr there isnt any holes but the metal, but there is an 3/32 deep relief. i removed the badge on my trunk and filled it with metal filler and smoothed it out.. a nice clean look imo rllywgn
September 21, 200619 yr Author thanks for the info, im thinking i will put in the subaru letter badge that I have in my avatar in that area for a nice clean looks to justify on the right while RX TURBO will be on the left, ill have to post pics when i do it on friday, have to get the car cleaned first :-p
September 21, 200619 yr im holding my 87 subaru gl-10 emblem in my hand it fell off, just like you were hoping :- ) it has two little suds in the back, both of them in the U's... the first one is a bit right of the center of the U channel, and a bit below the center of the middle horizontal line on the B. the second one is near the top of the U channel, set off to the right of the center. I would say its about half the distance to the right side upright, that it is to the left side upright. Im actually planning on taking some photos of my emblem, as it got water damaged really bad, BUT i think i can take some metallic silver model paint, and some black paint, and make it look almost new again. That, plus i got a new trunklid anyhow, off a loyale, so i need to remove the plain SUBARU one. I just checked my old trunklid, and there is also another hole there, next to the first stud. however, there is no trace of a stud in the hole or on the back of the emblem, in the middle of the letter B where the hole corresponds to. how is THAT for a thorough answer?!??? im a windbag, but thats all you could ever want to know about your 87 GL 10 trunk emblem, huh? heh, watch, youve got a wagon and my information is TOTALLY invalid. mine is a sedan, so maybe.
