reverse lights on in all gears..what the?...*sorted*
as the title says...my reverse lights have decided to turn on in all gears...but not if im in neutral:confused:...anyone else had this?
i had the reverse lights wired up so they worked with the wires on the new trans(FT D/R box)...and this they have done for the past month or so with no problems...until tonight when i put it into 1st and lit up the wall behind where i park.
where is the reverse switch on the FT4wd D/R 'box?....and what the hell would cause it to to turn on the reverse lights in all gears
cheers for any ideas
