November 11, 200322 yr The Rod bearings on an EA-82T are wider than those used in the non-turbo models. Every online parts place lists the same part number for turbo vs. non. Also, the newer parts catalogs list the same bearings for every motor, and the that part number is the narrower non-turbo bearing. The dealer wants $240 for a new set, and that is just highway robbery. So, does anybosy know where I can get aftermarket bearings of the same size? Does anybody know a manufacturer and part number for the correct bearing? Thanks, Keith
November 11, 200322 yr You can use the non-turbo bearings, or you can suck it up and buy them from the dealer. Try http://www.1stsubaruparts.com, about $180 for the turbo rod bearings, if I remember right. OR if you can can find a supplier of NDC bearings I can give you the actual NDC part #. (NDC is the supplier for Subaru) Good luck. I could not find an aftermarket source for turbo rod bearings.
November 11, 200322 yr Author Well, I did a bunch of diging on my own and found a Federal Mogul Sealed power part number and confimed with an engine builder I know that this part number is in fact wider than the standard part number listed. We were able to confirm this through a parts book from 1997. The part to order is a federal mogul 41065cp and can even be ordered from http://www.partsamerica.com Using a narrower rod bearing on a turbo motor is not a good Idea. Especially with a turbo where detonation and high rod bearing forces are more readily happening. I'm not sure what I would have done if I was not able to find the correct bearing. Keith
November 14, 200322 yr I did some digging around myself and found this. Took about 10 minutes, searching for "NDC engine bearings". NDC makes them for Subaru. http://www.power-auto-parts.com This is one of the better parts links that I have come across. Go there and search for your year, make, and model. They list a different part number for turbo and non- turbo bearings. Good price for EXACTLY the same thing you will get from the dealer.
November 14, 200322 yr Author Good Find! Thanks for the extra info. They ordered in the Federal Mogal bearings that I listed above and they arrived yesterday. Opened up the box and they are the right thing. Now for the intersting part. I paid $53 for the original and thinner non-turbo bearing set. These came in and only cost me $30. So, what looked like it was going to be a very expensive problem has turned out to be a cheaper problem! Thanks Keith
November 14, 200322 yr Glad to hear that things worked out for you. Thanks for sharing the Federal Mogul part #.
November 14, 200322 yr Author I sent a PM to Shawn to ask him to archive this so we dont lose this information. According to http://www.power-auto-parts.com the NDC part number is: A2030-32021 and retails for $33. Thanks all, Keith K.
November 15, 200322 yr Indeed, nothing wrong with Federal Mogul. For what it's worth, I would recommend that anyone replacing their bearings use the turbo version of the rod bearing. They are better, and like Keith pointed out, cheaper too. I am fairly certain that the rod bearings are the same for ea81 and ea82 1800cc engines.
November 15, 200322 yr THe NDC number should be something like CB2300, not the one you quoted. Are you absolutely positive these are NDC? Also, Michigan Clevite frequently repackages OEM bearings. You can tell by looking at the end of the bearing. It will have NDC stamped on it. Emily http://www.ccrengines.com
November 15, 200322 yr A2030-32021 is the http://www.power-auto-parts.com/ part number, not the NDC part number. They do sell NDC bearings, I called them to verify it.
