November 6, 200619 yr I've been thinking about putting a remote start system on my wagon. but am not exactly sure what all would be involved, and how easy it would be to wire into an EA82/EJ22 harness. I suppose the engine stuff would be pretty easy, just 2 wires, one for main relay, one for starter....but I'm not sure.... It's just too cold up here, and the darn thing cools itself far too well (more proof, that a stock EA82 radiator is more than enough to cool the EJ22), the temp gauge doesn't even come alive by the time I get to school. and I hate putting all those miles on it with it so drastically under operating temp.
November 6, 200619 yr remote starts are very easy to install. but i would caution you not to if your wagon is a manual. if left in gear it could start and drive off on you.( <=== this = No good) but easy enough to do... -=Suberdave=- http://www.suberdave.com
November 6, 200619 yr Author yea, it is a manual. and I do have the habit of leaving it in gear.... it'll be awhile before I can afford it, though...so maybe I'll start practicing leaving it in neutral with the handbrake on.
November 6, 200619 yr just 2 wires, one for main relay, one for starter....but I'm not sure.... Well, I put one on our 2000 Legaback, and there are a LOT more than two wires! Ours is an A/T, so maybe that is part of the equation. Still, read the instructions carefully, go slow and you shouldn't have any trouble. After living with the remote last winter, I don't know how we ever did without it. Bulldog remote starter kit - $49.95 (0n sale). Six-pack of beer to support installation crew (moi) - $6.95 The difference between climbing into a warm toasty windows defrosted car insted of a minus ten degree freezer locker - PRICELESS!
November 6, 200619 yr Check the thermostat if it's taking forever to warm up. A block heater might be cheap and easy too. Put it on a timed socket.
November 6, 200619 yr Or, even cheaper (like I do in the Barbie Jeep, cause the airplane is in my half of the heated garage) 100 watt bulb in a metal trouble light holder under the hood, padded moving blanket over the hood and windsheild. Redneck block heater? :-\
November 7, 200619 yr This is one of the reasons I'm trying hard to find the '88-'89 5spd D/R. I plan on doing the EJ swap eventually, and the '88-'89 trans has a neutral safety switch. Hook that into the remote start (I'm pretty sure this allows use of an "automatic transmission" kit instead of a manual trans one). Other than the transmission question, If you figured out all of the harness issues for the swap, installing the remote start should be cake.
November 7, 200619 yr remote starts are very easy to install. but i would caution you not to if your wagon is a manual. if left in gear it could start and drive off on you.( <=== this = No good) I've got remote start on my EA81T Brat and it's got a switch that connects to the gearstick. When the gearstick is forwards or backwards of neutral position it won't start. That takes care of the car driving off on you issue.
