funkyfish77 Posted November 11, 2006 Share Posted November 11, 2006 i'm looking for a good place to buy a short block for my outback (2.5) nothing fancy just a good rebuilt short block thanks for reading Quote Link to comment Share on other sites More sharing options...
Dspurr Posted November 11, 2006 Share Posted November 11, 2006 CCR the only way to go for a 2.5. No head gasket issues. 3 year 35k warranty.Mine runs great after 14k Quote Link to comment Share on other sites More sharing options...
ShawnW Posted November 11, 2006 Share Posted November 11, 2006 CCR the only way to go for a 2.5. No head gasket issues. 3 year 35k warranty.Mine runs great after 14k You need to contact CCR directly by phone for a quote but CCR will not warranty a shortblock for 3yr/36K....only 1yr/12k. This is because too many factors involved with final assembly of the engine come into play. You will also find that the cost savings is not worth it and at times CCR won't even sell a shortblock because of parts availability along with other reasons..at times they have to reserve available parts to be allocated for longblocks. The full longblock is a MUCH better deal as you get triple the warranty, all the new timing belt components, rebuilt and surfaced heads, timing belt plastic, genuine oil filter, metal breather plate for the back of the engine, platinum spark plugs, oil pan, tedious valve adjustment is done, piston slap is virtually if not 100% eliminated, etc along with the time savings compared to assembly yourself. Buying all the parts yourself to do the engine build right will probably meet or exceed the cost CCR charges for it already built and includes a warranty. Its a very expensive engine to build. If you do order a shortblock make sure your cyl heads are absolutely 100 percent flat and if theres any doubt take them to a shop and have them decked flat. Also be sure to order only Genuine Subaru head gaskets and if its a 96-99 DOHC engine make sure they provide you the updated multi layer gaskets. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 11, 2006 Share Posted November 11, 2006 I got mine from subaru with a 3/60, but then again they built the engine and it wasnt cheap. For the hell of it call Jamie maybe she can help. nipper Quote Link to comment Share on other sites More sharing options...
funkyfish77 Posted November 12, 2006 Author Share Posted November 12, 2006 thanks for the replys. i have heard good things about ccr. would i be able to do the 2.2 swap with a ccr engine (97 outback)? one more Q. do the ccr engines have any performance over the stock engines ? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 12, 2006 Share Posted November 12, 2006 CCR builds stock engines. and yes it will perfectly fit your vehicle. Quote Link to comment Share on other sites More sharing options...
funkyfish77 Posted November 12, 2006 Author Share Posted November 12, 2006 has the piston slap prob been fix on the ccr engines? Quote Link to comment Share on other sites More sharing options...
nipper Posted November 12, 2006 Share Posted November 12, 2006 has the piston slap prob been fix on the ccr engines? It has been fixed on the subaru short blocks. I cant even hear mine run anymore (so they most likely have fixed it on thiers too) nipper Quote Link to comment Share on other sites More sharing options...
ShawnW Posted November 12, 2006 Share Posted November 12, 2006 has the piston slap prob been fix on the ccr engines? Yes. Quote Link to comment Share on other sites More sharing options...
funkyfish77 Posted November 12, 2006 Author Share Posted November 12, 2006 thanks for the help! ithink i'm going with the long block instead of the short. going to get some prices tomarrow. Quote Link to comment Share on other sites More sharing options...
