4 speed shift shaft seal
hey guys
ive been searching for a shift shaft seal for my trans i got at the junk yard 4 speed single range out of '81 wagon, i got one from checker but it was too big, the dealer said they wanted $15 for it and it will take 2 weeks to get it, any ideas?
no one else around here has a listing for it
thanks
-Sam
take a good look at the seal
measure the ID, OD, and width in MM ex. 32-47-8
the numbers should also appear on the seal
the brand usually does not make much difference, and styles may vary
then look up the seal at SKF http://www.chicago-rawhide.com/catalogs/457010/stocklookup.asp
then call your seal supplier and provide them with the dimensions and the skf stock #
the seal from the example is 12733 which happens to be for bosch type ve injection pump input shaft seal, IIRC
well thanks, im not fond of dealers but..
-Sam
i wouldnt put most any other part in my car if it wasnt a dealer. learn to love em and your soobie will last forever :banana:
