November 13, 200322 yr Anybody know how the final drive ratios compare on the mid 80's 5spds and autos? e82t's specificially
November 13, 200322 yr As far as I know, all turbo's are 3.70, manual or autospastic, n/a manual's are 3.90, and most likely so are the auto's
November 14, 200322 yr fact in my units: 4EAT is 3.70 (EA82T 1988 wagon) 4wd 5spd S/R 3.90 w/rear diff lock 4wd 2WD MT? 2WD auto? I can't be factual on the rest because in the FSM book 1 i distinctly remember a listing of the turbo 2WD 5spd having a different ratio the the non-turbo 5spd and the 3AT supposedly has a 3.70 ratio as well.
November 14, 200322 yr 3AT also comes in 3.90. I've got an '87 GL wagon that used to have a bad auto trans, but I just got done swapping a 5-speed D/R into it, but luckily it had the 3.90 rear end so that was one fewer thing I had to swap.
November 14, 200322 yr zanny dook's wagon has a 3.9 4x4 automatic, spfi. the only one i have seen, the rest were 3.7 the pushbutton 5spd has a 3.7 dual range had 3.9 FT4WD xt6 5spds have a 3.9 rx ft4wd dual range has a 3.7 gear
