smelly_cat Posted November 25, 2006 Share Posted November 25, 2006 I have had this Sub sitting under a tree since 98, My toyota blew up, so I ripped out the mildew carpet and now drive ole reliable every day. With that in mind, The fuel gauge no work anymore , since I can go like 400 miles on a tank load, its not a big problem. Has anyone fixed their fuel gauge? Were should I start and note : the sending unit wont come of the off the tank because the nuts or bolts are rusted to the point of fusion. s/c Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted November 25, 2006 Share Posted November 25, 2006 I have had this Sub sitting under a tree since 98, My toyota blew up, so I ripped out the mildew carpet and now drive ole reliable every day. With that in mind, The fuel gauge no work anymore , since I can go like 400 miles on a tank load, its not a big problem. Has anyone fixed their fuel gauge? Were should I start and note : the sending unit wont come of the off the tank because the nuts or bolts are rusted to the point of fusion. s/c How does the wires look at the sending unit rustey? If so clean them. allso make sure the straps that hold the tank are not to rusty if they are you might not be getting a ground. Take a wire and hold it on the sending unit and then touch to a clean spot on the frame (no rust) and see if that does it and i think to test the gauge the same way . Touch the wire from the sending unit to a good ground with the car on and see if the gauge comes up. If so then you need a new sending unit and or better ground. Quote Link to comment Share on other sites More sharing options...
hatchsub Posted November 25, 2006 Share Posted November 25, 2006 I might have just gotten lucky but my fuel gauge in my first suby didnt work either because it had sat for a few years before i got it. So i didnt do anything about it and just filled up when i thought i needed to and and one day it just started working again. My only guess was that the sending unit in the tank got all gummed up and driving it and putting fresh gas in ungummed it. I would just drive it for awhile and see what happens. Just be careful not to run out of gas. Quote Link to comment Share on other sites More sharing options...
Prospeeder Posted November 25, 2006 Share Posted November 25, 2006 Mine didnt work because the wires in the trunk, coming from the tank got brittle, and broke, and corrded, so i bypassed the connector and spliced them together and it works! Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 25, 2006 Share Posted November 25, 2006 It's almost never the sending units - break out your ohmeter and check it. It's usually the wires. I couldn't even find where the wires had gone bad on my sedan (probably mice action), so I just ran new ones to the dash harness. GD Quote Link to comment Share on other sites More sharing options...
smelly_cat Posted November 28, 2006 Author Share Posted November 28, 2006 Thx folks. I'll give it try and let you know what happs. SC Quote Link to comment Share on other sites More sharing options...
smelly_cat Posted January 20, 2007 Author Share Posted January 20, 2007 Well it took me 2 months but I finally checked the wires. when i ground them . the reserve light goes on or the the gauge goes all the way to Full. So it appears the sending unit is a POS. I just reread, I need to check the ground . BRB SC Quote Link to comment Share on other sites More sharing options...
