December 5, 200619 yr Who had the rear disk brakes for the wagons? I need to upgrade and remember someone on the boards had them. Please let me know, I plan to start this early next month.
December 5, 200619 yr that is a good idea. The gl turbo wagons had them, and xt, and there is some swaps some board members did. If "who" meant an actual person with parts I musinderstood.
December 5, 200619 yr Yeah, anything turbo had 'em. If you have 4WD, you want 'em from a 4WD Turbo, non-sedan. If you have 2WD, you want 'em from anything 2WD Turbo. Same thing as Bgd said, if by "who", then I misunderstood. Check the for sale forum. There's like 4 people who have rear disks.
December 5, 200619 yr i took the whole rear trailing arms axels and the brake assembly from a 88RX that we where sending to the crusher when i worked at aaron's auto wrecking and it all bolted to my 86GL wagon, even used the RX brake lines.
December 5, 200619 yr i took the whole rear trailing arms axels and the brake assembly from a 88RX that we where sending to the crusher when i worked at aaron's auto wrecking and it all bolted to my 86GL wagon, even used the RX brake lines. That shouldn't be a surprise as they are the same platform. But working @ Aarons you probably already knew that!
December 5, 200619 yr Who had the rear disk brakes for the wagons? I need to upgrade and remember someone on the boards had them. Please let me know, I plan to start this early next month. Search the for sale forum. Edrach, baccaruda and others have some for sale right now. http://www.ultimatesubaru.org/forum/search.php?searchid=355245
