December 29, 200619 yr For '95 Legacy--searched every timing belt and cam sprocket post I could find (there are a lot!) and no one mentions what size socket is required. So . . . what size is it?
December 29, 200619 yr It's either 17mm or 19mm. If you going out to buy some sockets, the typical sizes on Subarus are 10mm 12mm 14mm 17mm 19mm. There are a couple of places were 8mm, 22mm and 32mm are used too.
December 29, 200619 yr Author Thanks GL. I'm good up to 19mm, just gotta' go buy a 22mm for the crank pulley. Aloha.
