reverse light switch
tonight i plugged in my reverse light switch and my 4x4 tell tale switch on my tranny. only problem is neither of them work. checked fuses and the discovered the ground wire running from the spare tire area towards the transmission doesnt go anywhere. does anyone know where that ground goes into the wiring for those switches? its a 92loyale with a d/r thanks!
That ground doesn't go into the wireing harness - it's connected to the tranmission itself. It's just a grounding strap from the body to the tranny housing.
You pick up a multi-meter yet? Those switches may not work like the push-button one's did..... I would have to look at it though.
