November 18, 200322 yr hey guys I need some input here. a buddy of mine has a 82d/r wagon that his wife drives, with problems though, it runs for about 30 min- 1 hour then quits. turns over fine but no fire. he replaced fuel system things ( pump,filter ) no luck. I have not had a chance to look at it yet but it sounds like ignitian or something,any words of wisdom would be helpful.
November 18, 200322 yr Sounds like ignition pick up module in the disty........ will it fire back up after cooling off for 30 mins or so......? if yes....go with my guess... its a common fail point... later, John in Oregon....
November 18, 200322 yr What John said.. I had the same problem in my 87 wagon... same symptoms.. was the ignition module
