pwoens Posted January 23, 2007 Share Posted January 23, 2007 my 93 turbo legacy 5 speed ran out of fluid and is shot....will a 92 non turbo 5spd from same legacy body style work??? Quote Link to comment Share on other sites More sharing options...
Snowman Posted January 23, 2007 Share Posted January 23, 2007 If you have a complete parts car, you can swap over anything else that might be different (i.e., the turbo car might have a hydraulic clutch). The big thing is making sure that you have the proper rear end ratio to match the tranny. Quote Link to comment Share on other sites More sharing options...
pwoens Posted January 23, 2007 Author Share Posted January 23, 2007 If you have a complete parts car, you can swap over anything else that might be different (i.e., the turbo car might have a hydraulic clutch). The big thing is making sure that you have the proper rear end ratio to match the tranny. cool...ya, the turbo has a hydro clutch... so will the trannys be exactly the same, like will bell housings and all that line up? So how do I tell if the ratio's are correct?? Quote Link to comment Share on other sites More sharing options...
weddes05 Posted January 23, 2007 Share Posted January 23, 2007 my hollander interchange states it should be a 3.90. most of the early legs tell you right on the rear diff tag Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted January 23, 2007 Share Posted January 23, 2007 All the 90-94 non-turbo 5spd trans. have a 4.111 final drive ratio. Only the turbo legacy MT has a 3.90 final drive ratio. Plus the clutch setup on the non-turbos will require pedal modification and stuff you don't want to do. I'd suggest trying to find another turbo legacy transmission Quote Link to comment Share on other sites More sharing options...
Snowman Posted January 23, 2007 Share Posted January 23, 2007 All the 90-94 non-turbo 5spd trans. have a 4.111 final drive ratio. Only the turbo legacy MT has a 3.90 final drive ratio. Plus the clutch setup on the non-turbos will require pedal modification and stuff you don't want to do. I'd suggest trying to find another turbo legacy transmission I know you've done a lot more work on the EJ cars than I have, so I'd generally take your word for it, but I'm curious why it wouldn't work to just swap out the whole pedal box. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted January 24, 2007 Share Posted January 24, 2007 Sure you could swap out the entire pedal box.....it's just a real pain in the butt to do that. Quote Link to comment Share on other sites More sharing options...
weddes05 Posted January 25, 2007 Share Posted January 25, 2007 contact blackbart, he has all kinds of turbo car parts, and he should deff have a trans for you. Quote Link to comment Share on other sites More sharing options...
