January 23, 200719 yr 96 Outback w/ DOHC 2.5L sometimes doesn't start....try several times with no joy....let it sit for a while....come back later starts right up. Suggestions? Warren C.
January 23, 200719 yr [...]Suggestions? We could use a bit more info. What exactly does "doesn't start" mean? Does it crank? If it cranks, does it fire at all, but won't actually run? Is the problem occurring when the engine is hot, cold, or temp doesn't seem to matter?
January 23, 200719 yr We could use a bit more info. What exactly does "doesn't start" mean? Does it crank? If it cranks, does it fire at all, but won't actually run? Is the problem occurring when the engine is hot, cold, or temp doesn't seem to matter? Also helpful if we know if this is an automatic or manual.
