February 19, 200719 yr i'm putting a weber on my wagon and need to replace the gaskets on either side of the adapter. the ones i used before were kinda rubbery and pretty stiff. they came for this application and i assume are the thing to use. i have three kinds of gasket material i can cut new ones from, one is rubbery but seems almost like straight up rubber, like a thick piece of innertube. not as stiff as the ones i'm replacing, but just as thick. one seems like a cork and rubber composite, i don't think that is the one to use. the last is sorta paper like, brown in color. seems like it would be good to use, but i worry about it being too thin. the rubbery one seems the most like the ones that i had on before, but i didn't think rubber was what you should use there. any suggestions?
February 19, 200719 yr The weber conversion manual says to use anaerobic sealant between the surfaces. As for the gasket...the paperish one should work.
February 19, 200719 yr Author what exactly is an anaerobic sealant? what i mean is what substances would work?
February 19, 200719 yr Author actualy i never used anything but the rubbery gasket before and didn't have priblems. i did use a little hi temp silicone on the bottom for the water preheat issue.
February 19, 200719 yr coat the paper material gasket with some fuel-safe sealant before you put it on, and let that dry overminght before installation. Anaerobic sealant is like RTV type stuff that cures without oxygen.. I am not entirely clear on whether it simply requires no oxygen to cure, or if it requires an ABSENCE of oxygen to cure... but the parts store guys can enlighten you on this, if no other board members do... BTW, your avatar is one of the coolest graphics I have ever seen on the internet, bar none.
February 19, 200719 yr If you use some JB weld and a bit of window screen to bock off the base heating coolant passage, you can just use regular paper gasket material without any sealant. The base heater passage really doesn't do anything anyway as the base of the carb is insulated from it by the adaptor and it's gaskets. Once you remove the possibility of a coolant leak, there's no need for any sealant. Makes removing the gaskets later easy, and they are generally re-usable. GD
February 19, 200719 yr I used part of a beer box to make one a few years ago. Never gave me any headaches. I also used some sealant for 2 stroke dirt bikes that is petroleum proof and it worked awesome. I still use that sealant to this day actually!
