Alvarezi Posted March 6, 2007 Share Posted March 6, 2007 Dear Subaru Fans! I have an "93 Legacy, and it died on me... The problem is I can't turn the ignition key at all. It seams the ignition lock is kind of loose... Can anybody help? Thanks Al Quote Link to comment Share on other sites More sharing options...
nipper Posted March 6, 2007 Share Posted March 6, 2007 Lock is loose, or the key is loose as in worn? nipper Quote Link to comment Share on other sites More sharing options...
Alvarezi Posted March 6, 2007 Author Share Posted March 6, 2007 Lock is loose, or the key is loose as in worn? nipper The lock is loose... Quote Link to comment Share on other sites More sharing options...
nipper Posted March 6, 2007 Share Posted March 6, 2007 the cylinder or the entire switch. you can remove the steering wheel trim to get access to look at it if your not sure. nipper Quote Link to comment Share on other sites More sharing options...
psylosyfer Posted March 18, 2007 Share Posted March 18, 2007 Does moving the steering wheel allow the key to turn? Quote Link to comment Share on other sites More sharing options...
