XT6 fogs on EA82 car
I want to install XT6 fogs on my 3-door. What all do I need from the XT6 to make it work? Any wires in particular, maybe a switch? What's a good way to run them?
It should be labeled. Either Foglight, or with the little D\\\ type thing..
It should fit in the blank spot for the rear gate latch, unless his car is 85-86 and has the power gate latch, in which case I THINK there is a blank spot on the left hand side of the steering wheel that the XT foglight switch will just snap into.
I have a blank spot on the left side for the rocker switch, but I'm still trying to figure out wiring (did 86's come pre-wired for fogs? My old '86 was)
It was a factory option, my white 86 brat did not have the wiring, but the maroon one I have now does. Still running the original subie relay!
Doesnt look like mine's wired for it...
So, how do I get them to work? I only have the lights and the switch. What kind of wiring and what kind of relay do i need?
also, the donor car is gone. and i didnt take the wiring :dead:
Go to pretty much any parts store, in the section where the fog lights are sold, look for a fog light wiring kit. Make sure you get one with a relay setup, otherwise you run the risk of burning the switch up, or wire fires.
