March 26, 200719 yr hello all. i wanted to know if there is an easy way to swap out for a different lug pattern on my 89 rx; or should i attmept milling down the current hubs. thank you.
March 26, 200719 yr Do a search for 5 lug conversions. You'll need a donor xt6 and some time. They have the 5x100 pattern same as the newer gen's.
March 26, 200719 yr Or just look in the USRM for the 5-lug conversion that I posted... And if you're lazy, here's the link for it. http://www.ultimatesubaru.org/forum/showthread.php?t=50400
March 27, 200719 yr I have seen people get their standard hubs converted to 4 x 100 and 4 x 114.3. It doesn't look to hard, is completely illegal here, but I can't see how it could be unsafe unless it was ghetto hand drill done. You'd want a machine shop to do it. They would have the right tooling for the job. If you can find an XT6, that is the way to go.. Better brakes as well I think.
March 28, 200719 yr I have seen people get their standard hubs converted to 4 x 100 and 4 x 114.3. It doesn't look to hard, is completely illegal here, but I can't see how it could be unsafe unless it was ghetto hand drill done. You'd want a machine shop to do it. They would have the right tooling for the job. If you can find an XT6, that is the way to go.. Better brakes as well I think. legacy fronts and use a XT6 for the rear. hubs are the key bit. if you are handy use the STI bits. I have WRX under mine with the rear XT6 hubs. (which are scarce out here.)
March 29, 200719 yr legacy fronts and use a XT6 for the rear. hubs are the key bit. if you are handy use the STI bits. I have WRX under mine with the rear XT6 hubs. (which are scarce out here.) And look into the rear e-brake mod using nissan calipers. Your front brake upgrades would be virtually limitless.
April 14, 200719 yr Author thank you. i currently work in a machine shop in Pitts. just wanted to know if anyone has had there hubs modified.
April 14, 200719 yr Author also does anyone in the pittsburgh area have a spare set of hubs (89 rx coupe) that i can practice with..?
April 16, 200719 yr also does anyone in the pittsburgh area have a spare set of hubs (89 rx coupe) that i can practice with..? For the fronts. You can use any EA82 hubs to practice with. I doubt anyone will give up the rears. Getting too hard to find for the rear disc conversion.
