SuBrat84 Posted March 27, 2007 Share Posted March 27, 2007 So, long story short here we are with Courtneys SECOND motor swap. Everything went more or less flawless. Started it up and with-in 30 seconds it threw P1507 Idle Control System Malfunction (Fail Safe) I don't even know what that means. Everything worked fine before (Except the ticking.) Right before she brought me the car she sprayed the engine bay out and it threw a knock sensor code.. but that went away once the car was dry. So then I swapped the motor.. and now here I am. I am going to call CCR tomarrow and see what they think. (If I don't get any good ideas here first.) I'm going to cry. I'm starting to feel like a failure or something.. even though the first motor wasnt my fault. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted March 27, 2007 Share Posted March 27, 2007 (this for '00obw AT): 11CN1: CHECK ANY OTHER DTC ON DISPLAY CHECK: Does the Subaru Select Monitor or OBD-II general scan tool indicate DTC P1510, P1511, P1512, P1513, P1514, P1515, P1516 or P1517? YES: Inspect DTC P1510, P1511, P1512, P1513, P1514, P1515, P1516 or P1517 using "11. Diagnostics Chart with Trouble Code for AT Vehicles". NOTE: In this case, it is not necessary to inspect DTC P0507. NO: Go to step 11CN2 . 11CN2: CHECK AIR INTAKE SYSTEM. Turn ignition switch to ON. Start engine, and idle it. Check the following items. Loose installation of intake manifold, idle air control solenoid valve and throttle body Cracks of intake manifold gasket, idle air control solenoid valve gasket and throttle body gasket Disconnections of vacuum hoses CHECK: Is there a fault in air intake system? YES: Repair air suction and leaks. NO: Go to step 11CN3 . 11CN3: CHECK THROTTLE CABLE. CHECK: Does throttle cable have play for adjustment? YES: Go to step 11CN4 . NO: Adjust throttle cable. 11CN4: CHECK AIR BY-PASS LINE. Turn ignition switch to OFF. Remove idle air control solenoid valve from throttle body. Confirm that there are no foreign particles in by-pass air line. CHECK: Are foreign particles in by-pass air line? YES: Remove foreign particles from by-pass air line. NO: Replace idle air control solenoid valve. Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted March 28, 2007 Author Share Posted March 28, 2007 It ended up being a dirty sensor in the intake manifold. Problem solved, runs great. Quote Link to comment Share on other sites More sharing options...
steamin53 Posted September 23, 2008 Share Posted September 23, 2008 Which sensor? Quote Link to comment Share on other sites More sharing options...
