March 31, 200719 yr My car has been acting funny and running poorly for a little while now. Today it completely crapped out on me. I went to pick up my gf and when she got in and i put it in reverse it died. Putting it in reverse had nothing to do with it though. The dash board lights up but nothing works on it. The power windows dont work and the car cranks over but wont start. I looked under the hood and noticed that my failing raditor was leaking on wires that run inside the cabin. Could this be the culprit right here?
March 31, 200719 yr Get ahold of a wiring diagram and see what those wires do. A good chance that they are the culprit.
March 31, 200719 yr My car has been acting funny and running poorly for a little while now. quote] Fuel pump or Carb probably.... just a guess...
March 31, 200719 yr Check all the fuses, the fusible links also. Un-bolt the fusible link box from inner fender and look at the wiring underneath it. Lost most of the power in my old '86 BRAT, found corroded connections under the link box. One of which had corroded to the point of breakage. As to the radiator leak, It "shouldn't" bother the wiring harness wires themselves, but it won't do any of the connectors any good, as it will lead to corrosion on them.
March 31, 200719 yr Author My car has been acting funny and running poorly for a little while now. quote] Fuel pump or Carb probably.... just a guess... Well i kno my carb probably needs replacing too but that wouldnt cause all my gauges along with my power windows and other things to not work.
March 31, 200719 yr Author Un-bolt the fusible link box from inner fender and look at the wiring underneath it. Lost most of the power in my old '86 BRAT, found corroded connections under the link box. One of which had corroded to the point of breakage. As to the radiator leak, It "shouldn't" bother the wiring harness wires themselves, but it won't do any of the connectors any good, as it will lead to corrosion on them. I looked and couldnt find the fusable links. Is it the grey box right behind the battery that holds them?
March 31, 200719 yr I dont know what I have left for EA81 stuff...but in general..if you need any help..let me know.. I feel your pain..Subarus should not be on the back of tow trucks..its just a sin...and not a pretty sight. I hope you had AAA
March 31, 200719 yr Author yea i have AAA plus so i have free towing for 100 miles. Its nice Its not so nice to have my baby towed..along with the window baged since i couldnt put it up anymore. At least i had it towed by someone who loves my car. He towed it two years ago when i didnt know quite as much about cars. He pulled his tow truck up last night and was like "how many miles you got on that thing now? You just dont forget a car that nice" At least i know its in good hands and is being put in a locked yard for first thing monday morning. Thanks for the help Connie. But last night and this morning i was thinking a blown fuse or fuseable link. I checked all the fuses in the fuse box and they were all good so it someithing in the engine compartment..i was too tired out from pushing my car down the street with my gf behind the wheel steering it into a parking spot so i wouldnt get a ticket..to check a bunch of stuff.
March 31, 200719 yr I looked and couldnt find the fusable links. Is it the grey box right behind the battery that holds them? That be the item you're looking for.. Small wire from battery + goes to it, just to help you find it. Cover has some lock-tabs that hold it on. May come off easy, may have to argue with it some, I know I've had to on a couple vehicles.... And just because they look good, don't mean they are good. They can/will burn and not damage the insulation covering them, may dis-color it some but not always. Best to use a meter to check them.
April 3, 200719 yr Author Its fixed. Turned out to be a fusable link that was making poor contact. Tightened it up and its all better now. Thanks for all the help
April 3, 200719 yr Its fixed. Turned out to be a fusable link that was making poor contact. Tightened it up and its all better now. Thanks for all the help :banana: I have been following this and am sooooo glad to hear it was something on the dumb/easy to fix side.
April 4, 200719 yr Author Yea so am I. It still doesnt idle super great but thats carb issues and it runs well enough to get me around without any problems so im not complaining now
