idosubaru Posted April 19, 2007 Share Posted April 19, 2007 i want to pick up some replacement trans hose so i can replace it tonight when i get home. anyone know what size it is for sure? 1997 Impreza OBS, though all 4EAT's being nearly identical i think most EJ's should be the same. Link to comment Share on other sites More sharing options...
Snowman Posted April 19, 2007 Share Posted April 19, 2007 I assume you're talking about the cooler lines? I've used 3/8" hose on EJ soobs ranging from 1990 to 2003 with no problems. Link to comment Share on other sites More sharing options...
porcupine73 Posted April 19, 2007 Share Posted April 19, 2007 Hi. I've been using 11/32 I.D. on mine which fits pretty good. Link to comment Share on other sites More sharing options...
avk Posted April 20, 2007 Share Posted April 20, 2007 OE molded hoses cost a ridiculous amount, at least for Impreza. Link to comment Share on other sites More sharing options...
idosubaru Posted April 20, 2007 Author Share Posted April 20, 2007 thanks guys, went perfect with the 3/8" as i had some of that. i just used straight transmission hose. none of the bends compromise the hose at all, so molded OE hoses aren't necessary for this application. next time i'm running straight hose from the ATF cooler all the way to the transmission to eliminate all those extra clamps in between. Link to comment Share on other sites More sharing options...
idosubaru Posted April 20, 2007 Author Share Posted April 20, 2007 OE molded hoses cost a ridiculous amount, at least for Impreza. oh yeah? i didn't even think to check with them. you sholud post the price if you know it! Link to comment Share on other sites More sharing options...
avk Posted April 20, 2007 Share Posted April 20, 2007 I did check the price when gathering parts before timing belt replacement. Thought about replacing those hoses when the radiator was out, but the cost put me off, even though I was paying with SubaruBucks. It was something like $35 for the longer pair in the front and $18 for the shorter pair in the back. Link to comment Share on other sites More sharing options...
idosubaru Posted April 20, 2007 Author Share Posted April 20, 2007 wow that's rediculous, more rediculous than i thought it would be. Link to comment Share on other sites More sharing options...
