April 21, 200718 yr Two pics I took while modifying the intake manifold coolant passage for the GM sensor so the MS can see the correct engine coolant temp. Ok, so three pics...but its still TWO of the turbo. You can see that i had to rotate the compressor housing some in order to clear the throttle cable...and it made for piping to be more simple. Also note the location of the MBC...works QUITE well! No boost spikes and great response and overall control.
April 21, 200718 yr nifty. what down pipe is that you are using? looks like it was extended in the same spot as mine.
April 22, 200718 yr Invidia catless. nice. i think mine is meant to be a knock off of that one, but all i know is that its an ebay special.
April 23, 200718 yr I had a Megan Racing 3" bellmouth on mine and I didn't have any clearance issues with it, but I didn't have a TWE header either. Just a stock header with a modified flange on it.
