crazy D Posted April 24, 2007 Share Posted April 24, 2007 its supposed to be easy!!! i have an '84 lifted wagon with a tranny from an '81 and i have tried and tried to fix this damn cable and it wont work...i checked the cable and it isnt brokenso i slipped it back in and it looks a little short ....but its longer than the spare i have.... i cut the little plastic housing on the tranny end so it colud get a little further down there but no luck with that either! what do you think is wrong? Quote Link to comment Share on other sites More sharing options...
Phizinza Posted April 24, 2007 Share Posted April 24, 2007 I have had this problem a few times now. I found the only way I could install a cable in my brothers wagon was when the gearbox was out of the car. Getting the right angle is a PITA! With my 5 speed conversion I had to cut the non threaded part off the gearbox side too, and it did work, but took ages (40mins or so) to get it to go in. And I was in a pit under the car, not crawling around under it... All I can give you as advice is keep trying.. :-\ Quote Link to comment Share on other sites More sharing options...
hatchsub Posted April 24, 2007 Share Posted April 24, 2007 Yea it took me about 10-15 minutes of turning it thinking it was in when it wasnt. All i can say is its not straight up and down. It leans a bit out towards the passenger side if that helps you any. just keep lining it up and applying pressure and it will go in eventually..and make sure your cable is lined up in the slot as well. Good luck. Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted April 24, 2007 Share Posted April 24, 2007 I've had the best luck pulling the plastic bolt thing back so just the end of the cable is there, and turn the end of the cable until it lines up with the slot in the gear in the transmission, and stuff it in as far as it will go, and then thread the plastic bolt thing in. It takes some practice but you'll get it :-) Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted April 24, 2007 Share Posted April 24, 2007 I've had the best luck pulling the plastic bolt thing back so just the end of the cable is there, and turn the end of the cable until it lines up with the slot in the gear in the transmission, and stuff it in as far as it will go, and then thread the plastic bolt thing in. It takes some practice but you'll get it :-) basically stick it in the hole:-p Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted April 24, 2007 Share Posted April 24, 2007 I've had the best luck pulling the plastic bolt thing back so just the end of the cable is there, and turn the end of the cable until it lines up with the slot in the gear in the transmission, and stuff it in as far as it will go, and then thread the plastic bolt thing in. It takes some practice but you'll get it :-) +1 That's the best way I've found to do it as well. Quote Link to comment Share on other sites More sharing options...
crazy D Posted April 25, 2007 Author Share Posted April 25, 2007 dang well thanks guys...im pretty sure ive done that too but i guess ill try ans try till i cant tries no more:) Quote Link to comment Share on other sites More sharing options...
idosubaru Posted May 14, 2012 Share Posted May 14, 2012 any further tips, helping my buddy with his XT6 and the threads simply won't engage.....? Quote Link to comment Share on other sites More sharing options...
man on the moon Posted May 14, 2012 Share Posted May 14, 2012 I had better luck doing it from the top than from underneath. Pull the working spade piece out as far as you can (within reason) and stuff it in place, then hold it via the cable housing while you mess with the threaded part. It takes a bit, but it will go in eventually. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted May 15, 2012 Share Posted May 15, 2012 my buddy figured it out (his car) - turns out the speedo cable they sold him was not the same - it has a thicker "bushing" at the base, that doesn't quite allow the threads to meet the threads in the trans. it was like 1/16" thicker, making it close enough to look like the threads should engage, but they won't. he grabbed the old sensor and noticed and it screwed right in no problems..... he's going to try to shave down the bushing and see if that works. i guess i should tell him to make sure it's long enough too... Quote Link to comment Share on other sites More sharing options...
man on the moon Posted May 15, 2012 Share Posted May 15, 2012 This is where I would say: Quote Link to comment Share on other sites More sharing options...
