04 automatic Forester 30k mile service ?s
Basically, I'm wondering what is really needed for a 30,000 mile service for my vehicle. I am not a mechanic and will be paying someone else my *hard-earned* money to do it. The manual states:
Inspect:
drive belt
camshaft drive belt
fuel system, lines and connections
transmission/diff. (front and rear) lubricants (gear oil)
auto. trans. fluid
disc brake pads and discs, front and rear axle boots and axle shaft joint portions
brake linings and drums
clutch operation
steering and suspension
Replace:
engine oil
engine oil filter
fuel filter
air cleaner element
spark plugs
brake fluid
Perform:
replace engine coolant and inspect cooling system, hoses, and connections
inspect brake lines and check operation of parking and service brake system
rotate and inspect tires
Out of this list, what do I not need (if anything)? Anything not covered that I should have done?
I have talked to a mechanic who, after looking up my vehicle in whatever book or database he had, said that I should not need spark plugs (despite what the owner's manual says). He thought there should be platinum plugs in there that are good to 100k. I understand replacing them bumps up the price substantially.
I didn't find a thread that related directly when I searched and thought some knowledgable answers in one place on this topic would be much appreciated by more members than just me.
So, basically, what should I have done?
Subaru is really too heavy on thier 30K maint, i dont know why since everyone else is going towards 100K on some things. I think they are written to make the dealer money.
Any shop worth thier salt will do the inspected items any time any car gets on the lift.
Brake fluid - wait till the car need brakes. Most mfg are going with 100k or life of the car maint intervals for that item. Its a waste of money to have it done now. WHen the brakes are done, have them bleed the brakes.
Spark plugs, as long as the car is running fine, passes emissions, and no change in gas mileage they can go for quite some time (your mechanic is correct).
Fuel Filter yes.
Air cleaner if needed.
Drive belts only if your mechanic thinks it needs them.
Engine coolant flush and replace. This keeps the system clean and the water pump happy.
I am surprised that a tranny flush is not in there. Thats very important on the automatic transmissions. It keeps the AWD very happy, and thats a 3 year interval.
nipper
PS of course do the oil change too.
So I should add in a tranny flush, then?
I just looked at www.cars101.com
Its dumb, it says inspect. You should check the fluids in the car more then once every 30,000 miles.
We have found here on USMB that every 30K makes for a very happy transmission. SUbarus will practically get your morning newspaper and slippers for you if you regularly change the tranny fluid.
I do mine every 30K (and Blu is at 205,000 miles).
nipper
Very helpful. Thanks.
Weird, but I'm subscribed to this thread and I've not gotten any e-mail notifications.
Also, I've got two cans of SeaFoam just sitting in my garage begging to be used. Do you think it'd be helpful if I did this 500 miles (I think that's what I remember reading) before I took it to the mechanic?
I'm not a big fan of using additives just because you have them.....
Back away from the seafoam .......
nipper
Can you tell me more about why you don't like Seafoam? I ask because it seems like everybody and their cousin here thinks it's the coolest thing ever and I usually kind of go with the flow on those things. Do you think it has some good uses like as a fuel additive or something?
They have thier place, but at 30,000 miles you shouldnt need it. You shouldnt need it untill you get over 100,000 miles.
nipper
Just got done removing a stump from my backyard. Maybe I could have just used it to burn the stump out. :Flame:
FIRE!
