4EAT pan protection?
Anyone out there made a skid plate for their 4EAT trans pan?
I have my oil pan and rear diff protected, but the trans pan is still open to bombardment. Where did you mount yours to?
-Ben
I don't believe it would be hard to make a skidplate for the 4EAT. Usel a flat piece of 1/4 plate cut to the size of the pan. Then replace 4 of the pans corner bolts with studs. Use a nut on the stud to hold the pan lip. Then put a sleeve over the stud long enough to clear the pan, then bolt the plate onto the studs with the sleeve as a spacer. With the combined thickness of the pan and the plate you would never punch it hard enough to bust through. Espescially if you welded some ribs to it.
bolting a skidplate to the tranny is a bad idea....assuming you're actually going to use it.
the smart thing to do, would be something bolted to the engine crossmember, and then to a custom crossmember behind the tranny somewhere....
What about the tranny rear crossmember? it might need some extending or something or a weird shaped pan, but it seems stout enough since its holding the tranny in place.
Better than no skid plate. It would keep you from puncturing the pan. I try NOT to use the skidplate and if you pick a proper line you won't. I just worry about being belly deep in ruts sliding on a mud ridge in the middle, then oops a rock! Making essentially a beefier pan would prevent damage in that case. I'm not talking bout Rubicon style rock crawlin here. Just protection from the occasianal buried rock in the mud or snow.
I think the problem would be that if you do hit something you might actually break the case where the extended bolt went into.
Naaaa... I think it'd be fine if you made the attachments tough. This is how I am gonna setup mine
it could work, but it still makes me extremely nervous.
had a guy in the North Shore Wheelers in his Cherokee get hung up on a rock on his tranny skid (which was essentially just a reinforced pan), which ripped his tranny mount, tipped the whole assembly forward, and his rad fan punched a huge hole in his radiator.
Seems like more extreme conditions than I would be facing. And with the placement of the Engine and trans balanced on the crossmember I can't see the engine tilting like a long jeep 4.0 or V8. If I was going seriously hard core offroad/crawling I would do a bit beefier design, seperate from pan. But the title of this thread is "pan protection" not "how to make a soob indestructible"
