Rebuild
does it not run? you can buy a replacement at a junk yard for -$100.
i hate to be an a$$ but if it ain`t broke don`t fix it. that is unless you want it to be a learning experience in which case it would probly take you no longer then 2 to 4 days off having the correct tools, a manual, and all parts in hand.
good luck
I'm not sure, never timed it. I have always had a spare engine before needing to rebuild (actually, only headgasket up for EA82). It isn't something to rush if you haven't done much of this stuff.
