Reverse drags....Torque converter?????
Sounds more like torque bind. Put the fuse in the FWD holder and see if it goes away.
Do all your tires match?
Are they all properly inflated?
Is your tranny temp light on?
Drive the car at idle speed in a tight circle. Can it move under its own power at no throtle in forwad and reverse. If it can't its TB.
If its TB, change the fluid. At this mileage I wouldnt be surprised if the AWD is worn out.
nipper
nipper
us 89-94 guys call it a "power light". See if it flashes on startup.
