idosubaru Posted August 9, 2007 Share Posted August 9, 2007 i'm seeing that the impreza RS changed calipers from 01 to 02. anyone know what the difference is? NASIOC and USMB info only shows 98-01 impreza RS stuff from what i've found, can't find much about the 02+ RS spec's. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted August 9, 2007 Share Posted August 9, 2007 Couldn't find a whole lot either. From the part #'s it looks like 02-06 shared the same calipers for all non-turbo/non-wrx impezas, whereas previously the RS had it's own different number. cars101.com: 2002: Front: 10.7" vented twin-caliper piston. Rear: 10.3" solid disc 4 channel, 4 sensor ABS (anti-lock) 2001: Front: 10.7" vented disc with dual caliper pistons, Rear:10.5" solid disc 4 channel ABS Quote Link to comment Share on other sites More sharing options...
jamal Posted August 9, 2007 Share Posted August 9, 2007 Caliper is the same. There was a caliper bracket and pad change, although it doesn't correspond exactly to model year and the only way to tell the difference is to actually look at the pads. http://www.stoptech.com/tech_info/faq_wrxcalipers.shtml Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 9, 2007 Author Share Posted August 9, 2007 ha ha, jamal thanks for piping in. wanted to speak to you about it! so no matter which way i go...whether it's 01 or 02+, just make sure i get the corresponding bracket to go with that caliper and it'll bolt right up right? rotors and calipers are the same. brackets and pads are different? Quote Link to comment Share on other sites More sharing options...
jamal Posted August 9, 2007 Share Posted August 9, 2007 correct. The change occurred on the front and rear of rs and wrx imprezas sometime in 02-03, and not even at the same time for both models. Reason probably being that they still had brackets left at the factory and used them until they ran out. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 9, 2007 Author Share Posted August 9, 2007 thanks jamal. i have your caliper brake-down on my computer and i'm confused: 260x24mm.......... Applications: 90-99 Legacy non-turbo/-GT/-Outback 276x24mm........ Applications: 91-94 Legacy turbo 96-02 Legacy GT/Outback am i reading it wrong so that it looks like 96-99 Legacy GT's fit under both categories? i have a 97 Legacy GT at home, so i can find out by looking if it's the first (single pot) or second (double pot - which is what i thought they were)) variety, but figured i'd mention it. Quote Link to comment Share on other sites More sharing options...
jamal Posted August 9, 2007 Share Posted August 9, 2007 no, by non-turbo/-gt/-outback, I mean non-turbo, non-gt, non-outback. And probably non LSi, and some 96-99 OBs might also have smaller discs. My nasioc version of that thread is slighty updated and I plan to replace the one here shortly. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 10, 2007 Author Share Posted August 10, 2007 gah, i figured i was reading it wrong but was not seeing it. thanks j! Quote Link to comment Share on other sites More sharing options...
