March 19, 20224 yr Good thread dig! I found my horn would only work at certain angles of the steering wheel. Turns out the little pin that slides on the ring of the steering wheel had worn down so far that it wasn’t always in contact with the ring. I found a used .22 rifle shell fitted perfect over the pin on the steering column and my horn worked perfect ever since. To fix this the steering wheel has to be removed. Cheers Bennie
