eryque Posted August 14, 2007 Share Posted August 14, 2007 I'm curious about whether you need to actually remove the engine to replace the mounts, or if you can just support it enough (maybe with a jack or something) to slip the mounts out and slip the new ones in. Draining the coolant and undoing and redoing all those connections doesn't sound like a lot of fun if I can avoid it. When replacing the mounts, is it necessary to also replace those round rubber baby buggy bumpers at the rear? Do they wear out enough to cause problems? Quote Link to comment Share on other sites More sharing options...
Petersubaru Posted August 14, 2007 Share Posted August 14, 2007 I'm curious about whether you need to actually remove the engine to replace the mounts, or if you can just support it enough (maybe with a jack or something) to slip the mounts out and slip the new ones in. Draining the coolant and undoing and redoing all those connections doesn't sound like a lot of fun if I can avoid it. When replacing the mounts, is it necessary to also replace those round rubber baby buggy bumpers at the rear? Do they wear out enough to cause problems? ` Quote Link to comment Share on other sites More sharing options...
NoEyeSquareGuy Posted August 14, 2007 Share Posted August 14, 2007 Not necessary to pull the engine. See instructions and pics here: http://www.scoobymods.com/forums/showthread.php?t=470&highlight=engine+mounts Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 14, 2007 Share Posted August 14, 2007 I'm not sure what you are asking about at the end. Are you meaning the pitch stopper? If so, yes those do sometimes wear out over time. If you are so inclined now whould be a good time to replace the transmission mount as well. If you are a spirited driver a weak transmission mount can lead to transmission troubles as well. STi Group N mounts are direct replacement for all of the mounts on your car, and they are not really expensive. If you haven't checked into them they are worth a look. Quote Link to comment Share on other sites More sharing options...
eryque Posted August 14, 2007 Author Share Posted August 14, 2007 I'm not sure what you are asking about at the end. Are you meaning the pitch stopper? If so, yes those do sometimes wear out over time. There are two round cushions on the back that are very, very expensive. Those are the ones I was talking about. Thanks so much for the link. The procedure was about what I'd planned on doing, but with a couple of refinements. The pictures help a lot. Quote Link to comment Share on other sites More sharing options...
Virrdog Posted August 15, 2007 Share Posted August 15, 2007 There are two round cushions on the back that are very, very expensive. Those are the ones I was talking about. Do you have a picture of what you are talking about? Quote Link to comment Share on other sites More sharing options...
