December 6, 200322 yr I posted this on legacycentral....but figured I wouldn't leave you out of the dark Well....I wouldn't want you guys to think I don't like you and not get you a Christmas present.....so I'm going to inundate you with info.Larry posted a link over on the BC-BF List for these parts & service manuals. This guy apparently scanned them in because he used an EJ22 motor in his airplane. Well the scans were a little hard to navigate....so being me, I added bookmarks to the pdfs so you have a nice index structure to see what's all in the pdf. The FSM & Parts manuals only include the engine/electrical pages, but contain most of the important stuff.Here's the original sitehttp://www.finleyweb.net/default.asp?id=142Please right click and save the pdf's. Thanks!Here is the root link for all the service manualshttp://www.main.experiencetherave.com/subaru_manual_scans/1992 FSM (Engine & Electrical)http://www.main.experiencetherave.com/subaru_manual_scans/1992_FSM_Eng_and_Elect/1990-1994 Parts Manualhttp://www.main.experiencetherave.com/subaru_manual_scans/1990-1994_Legacy_Parts_Catalog_-_FULL/ 1992 Service Bulletinshttp://www.main.experiencetherave.com/subaru_manual_scans/Subaru_Service_Bulletins/Don't forget the other scans I already have there.Also, some of you know this, but I have scanned my entire owner's manual as well.You can look at each page or d/l a complete pdf filehttp://www.main.experiencetherave.com/owner/Like I said, there's A LOT of info in these pdf's. The service bulletins have a lot of good info too.Enjoy
December 6, 200322 yr Author Now for the index of everything 1990-1994 Subaru Legacy Parts Manual – Engine* Illustrated Index* Group Index* Short Block Engine* Gasket & Seal Kit (Engine)* Cylinder Block* Timing Hole Plug & Transmission Bolt* Cylinder Head* Piston & Crankshaft* Flywheel* Camshaft & Cambelt* Valve & Valve Rocker* Rocker Cover & Oil Filler Duct* Timing Belt Cover (To Dec ’92)* Timing Belt Cover (From Jan ’93)* Oil Pan* Oil Pump & Oil Filter* Oil Cooler; Turbo (‘91MY)* Water Pump; NA* Water Pump; Turbo* Turbo Charger System* Intake Manifold; NA (’90 & ‘91MYS)* Intake Manifold; NA (’92 & ‘94MYS)* Intake Manifold; Turbo* Air Cleaner* Air Duct* Fuel Pipe System* Fuel Injector* Engine Cooling System; NA* Engine Cooling System; Turbo* Throttle Body & Air Duct* Alternator Bracket & V Belt* Spark Plug & High Tension Cord* Wiring Harness-Engine; NA* Wiring Harness-Engine; Turbo* Starter (1) MT (1.0KW)* Starter (2) AT (1.4KW)* Alternator* Hose & Clamp (P.C.V.); NA* Hose & Clamp (P.C.V.); Turbo* Emission Cont System; Turbo* Engine Electrical Parts 1992 FSM (Engine & Electrical)* Table of Contents* 1-1 Specifications* 2 Engine Section Index* 2-1 Emission Control System and Vacuum Fitting* System Application* Schematic Drawing* General Precautions* Crankcase Emission Control System* Ignition Control System* Evaporative Emission Control System* Vacuum Fitting* 2-2 On-Car Services* Foreword* Engine Compression* Intake Manifold Vacuum* Hydraulic Lash Adjuster* Fuel Injector* Oxygen (O2) Sensor* 2-3 Engine* Mechanism and Function* General* Timing Belt* Belt Tension Adjuster* Belt Cover* Valve Rocker ASSY* Hydraulic Lash Adjuster* Cam Shaft* Cylinder Head* Cylinder Block* Crankshaft* Piston* Specifications and Service Data* Specifications* Service Data* Component Parts* Timing Belt* Cylinder Head and Camshaft* Cylinder Head and Valve ASSY* Cylinder Block* Crankshaft and Piston* Service Procedure* General Precautions* Timing Belt* Valve Rocker ASSY* Camshaft* Cylinder Head* Cylinder Block* Troubleshooting* Engine Trouble in General* Engine Noise* 2-4 Engine Lubrication System* Mechanism and Function* General* Lubrication Lines* Oil Pump* Oil Filter* Oil Pan & Oil Strainer* Oil Pressure Switch* Specifications and Service Data* Component Parts* Oil Pump* Service Procedure* Oil Pump* Troubleshooting* 2-5 Engine Cooling System* Mechanism and Function* General* Cooling Lines* Water Pump* Mechanical Seal* Thermostat* Coolant Filler Tank* Specifications and Service Data* Specifications* Service Data* Component Parts* Water Pump* Radiator and Radiator Fan* Water Pipe* Service Procedure* Water Pump* Thermostat* Radiator* Radiator Cap (Filler Tank Cap on Turbo Model)* Radiator Fan and Fan Motor* Coolant Filler Tank* Troubleshooting* 2-7 Fuel Injection System* Mechanism and Function* General* Air Line* Fuel Line* Sensor and Switch* Control System* Self-diagnosis System* Turbocharger System* Component Parts* Intake Manifold* Air Intake Duct and Throttle Body* Air Cleaner* Turbocharger Unit* Service Procedure* Turbocharger System* Troubleshooting* Supplemental Restraint System “Airbag”* Precautions* Pre-inspection* Troubleshooting Chart for Self-diagnosis System* Output Modes of Select Monitor* Control Unit I/O Signal* Troubleshooting for Engine Starting Failure* Troubleshooting Chart with Trouble Code* Troubleshooting Chart with Select Monitor* General Troubleshooting Table* 2-8 Fuel System* Mechanism and Function* Fuel Lines* Specifications and Service Data* 6-1 Engine Electrical System* Specifications and Service Data* Component Parts* Starter* Alternator* Service Procedure* Starter* Alternator* Spark Plug* Ignition Coil* Spark Plug Cord* Troubleshooting* Starter* Alternator* 6-2 Body Electrical System* Engine Electrical (MPFI)* Radiator Fan* Lighting* Cruise Control* 6-3 Wiring Diagram and Troubleshooting* General Description* Working Precautions* How to Use Wiring Diagram* How to Use Super Multiple Junctions (S.M.J.)* Wiring Diagram and Troubleshooting* Power Supply Routing* Charging* Starting* Engine Electrical* Radiator Fan* Lighting (Headlight)* Lighting (Tail, Illumination, etc.)* Room Light and Door Switch* Stop Light* Turn Signal and Hazard* Trunk Room Light* Back-up Light* A/T Control* A/T Shift Lock* Electrical Unit Location* Compressor Map – IHI BRL4016 (EJ22 Turbo) 1992 Subaru Service Bulletins* 2.2L 4-Cyl & 2.2L 4-Cyl Turbo – VIN (6)* Removal & Installation* Overhaul* Engine Oiling* Water Pump R & I* Torque Specifications* Engine Specifications* Interference Verification Check for OHC Engine* Specifications* Capacities* Quick-Service* Mechanical Checks* Ignition System* Fuel System* Theory/Operation* Air Induction System* Computerized Engine Controls* Fuel System (Carbureted)* Fuel System (Fuel Injected)* Ignition Systems* Emission Systems* Self-Diagnostics* Basic Testing* Fuel System* Ignition Checks* Idle Speed & Ignition Timing* Fuel Pump Circuit Tests* Tests W/Codes* Self-Diagnostic System* Diagnostic Code Charts* Read Memory Mode* D-Check Mode* Clear Memory Mode* Crank Angle Sensor* Starter Switch* Cam Angle Sensor* Fuel Injectors* Coolant (Water) Temperature Sensor* Knock Sensor* Airflow Meter Circuit* By-pass Air Control Valve* Throttle Position Sensor* Oxygen (O2) Sensor* Vehicle Speed Sensor No. 2* Canister Purge Control (CPC) Solenoid Valve* Air/Fuel Ratio Control System* Idle Switch* Wastegate Control Duty Solenoid Valve (Turbo)* Pressure Sensor Duty Solenoid* Atmospheric Pressure Sensor (Non-Turbo)* Airflow Sensor* Neutral Safety Switch (Man. Trans.)* Inhibitor Switch (Auto. Trans.)* Parking Brake Switch (Auto. Trans.)* Tests W/O Codes* Symptom Diagnosis (Carbureted – Justy)* Justy Symptom Diagnostic Chart* Loyale Symptom Diagnostic Chart* Legacy Symptom Diagnostic Chart* SVX Symptom Diagnostic Chart* Intermittent Problem Diagnosis* Wiring Diagrams* Wiring Diagram (Legacy 2.2L PFI & Turbo)* Component Location Menu* Engine Compartment, Headlights (Grid 1-3)* MPFI Control Unit (Non Turbo), Ignition Relay (Grid 4-7)* Check Connector, Ignition Coil (Non Turbo) (Grid 8-11)* MPFI Control Unit (Turbo) (Grid 12-15)* Check Connector, Ignition Coil (Turbo) (Grid 16-19)* Fuse Relay Box, Ignition Switch (Grid 20-23)* A/T Control Unit, Shift Lock Control Unit (Grid 24-27)* ABS Control Unit, Cruise Control Unit (Grid 28-31)* Air Suspension Sensors, Height Control Unit (Grid 32-35)* A/C Relay Box, Air Bag Control Unit (Grid 36-39)* Front Wiper Motor, Hazard Sw (Grid 40-43)* Instrument Cluster, Dome Light (Grid 44-47)* Auto Shoulder Belt Control Unit, Pwr Windows (Grid 48-51)* Power Mirror/Sunroof Sw, Tail Lights (Grid 52-55)* Electrical Component Locator* Buzzers, Relays, & Timers* Circuit Protection Devices* Control Units* Motors* Sending Units & Sensors* Solenoids & Solenoid Valves* Switches* Miscellaneous* Trouble Code 13 – Crank Angle Sensor* Vacuum Diagrams* Remove/Install/Overhaul – Turbocharger (Legacy)* Effects of Incorrect Fuel Use: New Procedure* Incorrect Oil Pump Cover Torque: New Specification* Fuel Injector Replacement* Incorrect Duty/ID/Data Charts: New Charts* Updated Line Pressure Duty Diagram (1990 Legacy)* Updated Line Pressure Duty Diagram (1991-92 Legacy)* Updated Line Pressure Duty Diagram (1992 SVX)* Updated Cartridge I.D. Chart for Select Monitor* Updated A/T Data Ranges (1990 Legacy)* Updated A/T Data Ranges (1991-92 Legacy)* Low RVP Fuel Effects: New A/T ECU-ROM Installation* Omitted Fuel Gauge Delay Amplifier: Not Used in USA
December 25, 200322 yr Actually, I e-mailed him, trying to find out which manual/year the info on EA-81 came from, and the guy didn't know much about what he had. My guess is that he didn't scan them himself... I wonder where he got them and what else is out there?! Too bad they don't have complete manuals for later years, as they have for 1989 -- that one is scanned PERFECTLY and is 100% complete, not just the engine section. Not that I need any of it, but I downloaded it all -- you never know.
October 24, 200421 yr Author I've added some more goodies. All can be found herehttp://www.main.experiencetherave.com/subaru_manual_scans/Again, Please right click and save the pdf's. Thanks1980_Subaru_Manuals1990_Legacy_FSM_Supplement1990_Legacy_Owner_Manual_Scans1990-1994_Legacy_Parts_Manual_-_Engine1992_FSM_(Engine_&_Electrical)1992_Subaru_Service_Bulletins1999_Legacy_FSM2000+_Legacy_FSM2002_WRX_FSM2004_Impreza_WRX_STi_Factory_Service_ManualChiltonsFSM_ScansSubaru_Service_BulletinsTechnicians_Reference_Booklets
January 16, 200521 yr The links and documents below have been a fantastic resource for working on my '90 Legacy LS wagon. Thanks! I'm in need of the Service Manual information for Section 3, Transmission and Differential of the SubaruEJ-22 Repair Manuals. The links below (specifically, EJ22 Repair Manual2) appear to have this Section missing. Would you happen to have this also? (I'm out of work, so $$$ are an issue.) It appears I have a Duty Solenoid "B" problem (as translated by the "Power" light flashes). I have the 4EAT in my Legacy - FWD. On a related note, is there any long-term concern if I'd just ignore this? It seems to run fine (I've owned it for 9 months - put 5K miles on it - it has 170K.) Thanks! I posted this on legacycentral....but figured I wouldn't leave you out of the dark Well....I wouldn't want you guys to think I don't like you and not get you a Christmas present.....so I'm going to inundate you with info. Larry posted a link over on the BC-BF List for these parts & service manuals. This guy apparently scanned them in because he used an EJ22 motor in his airplane. Well the scans were a little hard to navigate....so being me, I added bookmarks to the pdfs so you have a nice index structure to see what's all in the pdf. The FSM & Parts manuals only include the engine/electrical pages, but contain most of the important stuff. Here's the original site http://www.finleyweb.net/default.asp?id=142 Please right click and save the pdf's. Thanks! Here is the root link for all the service manuals http://www.main.experiencetherave.com:8080/subaru_manual_scans/ 1992 FSM (Engine & Electrical) http://www.main.experiencetherave.com:8080/subaru_manual_scans/1992_FSM_(Engine_%26_Electrical)/ 1990-1994 Parts Manual (Engine) http://www.main.experiencetherave.com:8080/subaru_manual_scans/1990-1994_Legacy_Parts_Manual_-_Engine/ 1992 Service Bulletins http://www.main.experiencetherave.com:8080/subaru_manual_scans/Subaru_Service_Bulletins/ Don't forget the other scans I already have there. Also, some of you know this, but I have scanned my entire owner's manual as well. You can look at each page or d/l a complete pdf file http://www.main.experiencetherave.com:8080/owner/ Like I said, there's A LOT of info in these pdf's. The service bulletins have a lot of good info too. Enjoy
