transmission and back axel
Hi There,
i had to replace my Automatic transmission on my 1996 outback AWD.it was knocking alot the mechanic Guy suggested to change it.
we did the job till now 8 times.
he had to get them from used and not new.
the last one is for an 2000 impreza, turbo.it works fine but not on AWD i had to put the fuse in the box of FWD.
he decided to change the rear gear, it still have the same problem.
it vibrates alot on 1st and it jams on AWD.
he said we have to find the right back gear for this transmission.
i asked him how to do so he said we have to try since there is nothing written that tells you this gear goes with this transmission.
can anyone help me how to identify what gear should go with my transmission or how to identify it.
Thanks in advance.
Regards.
Hi Antwert. Yes it sounds like the final drive ratio of the transaxle you are installing does not match the ratio of the rear diff. Check out these articles:
Correct axle ratios
Outback Gear Ratios
If you have some info about your transmission serial # I know there are people here who can tell you the ratio, for U.S. spec vehicles anyway.
Correct axle ratios
Outback Gear Ratios
Thanks for the valuable information,
do you think there is a chart to identify the transmission with the right rear gear or only with the serial No.??
it's a bit late now to open the hood and try to take the serial No of the transmission. i will take it tomorrow and give it back to you.
Thanks again for the great help.
you've replaced the transmission EIGHT TIMES? that's jacked up.
remove the front differential drain plug and count the teeth on the gear.
over here that would be a bad swap - the 99 and up transmissions have some major design differences and there could easily be differences between a 2000 and 1996 transmission. over here a 2000 transmission will have a spin on oil filter, the 1996 will not. you may be dealing with wiring issues, more on that later.
jack up the rear of the vehicle and turn the rear wheel. count how many times the driveshaft turns for each turn of the wheel. 41 turns of one to 10 turns of the other gives you a 4.11 gear ration. 44 turns of one to 10 turns of the other gives you a 4.44. i would imagine those are your two options 4.44 or 4.11
i wouldn't waste my time trying to find the gear ratio out, just start counting like i said about. automatic transmissions do not have a lot of information out there about final drive ratios, it's asked all the time on here and it's even tough to get answers here in the states. i would not assume that what we got here is identical to what you got there, so it becomes even worse for you. i'd start counting to be sure.
also check the duty C and FWD circuitry, you may be mixing and matching transmissions with different wiring. you should be able to do some basic wiring/circuitry testing - continuity and the like to make sure your duty C and FWD switch wiring is the same.
Thank you GroosGary for your Reply,
my outback is an American, it was imported from the US.
may be thats why we're having hard time to find the right gear for it.
the transmission on it now is an Impreza turbo 2000.
i'll try to do the counting and check what it is.
lets say it's an 4.11 ratio which gear will fit on it???
Thank you
Regards.
Correct axle ratios
Outback Gear Ratios
Hi Again,
i got the numbers on the Transmission and the rear diff too
transmission: TZ102YBABA-CF
793254
the rear gear has 2 letters painted with white color: TP
Thank you for the great help.
Anwar
i'm not sure what you mean.
yours is probably a 4.44 gear ratio - so your rear differential is probably a 4.44. you'll likely need a 4.11. but....again, you've done this "8 times" you said? with the same transmission, different transmission, different rear differentials?
i don't know if anyone is going to come up with the final drive for you just based on the part numbers, i've seen others try to do that and not get anywhere.
hi,
yes 8 times,
1st time we figured that the car is waving right and left, we took the transmission and changed it with another one.
2nd time the transmission was a bit slow to shift on 1st gear and reverse also same waving.
3rd time another transmission still having same problem and the car Jams on AWD.
4th time we took the transmission off and replace the front differential with the old one that used to be on the car when it came from the states.
5th time the differential didn't work on the transmission i don't know the reason, but with a drive test it was noisy like if the differential has no oil in it.
6th time we took off the transmission and try to figure out why the noise. it didn't work
7th time another transmission, still not working on AWD and after 2 days it start lacking after it warms up.
8th time the one that i have on the car now.
not with the good ratio cause the car Jams on AWD,
  • we did change the rear gear with another one, the car used to have a gear with 2 big letters painted on top of it: TP, the one that we installed is TM, the mechanic guy said he want to try this time a gear with TR code.
it's a big mess i know i started to hate Subaru but i can't i like this Car.
i want to fix it, i don't care how much it costs.
i can't blame the mechanic guy cause the specs over here are different from the specs in the states.
Thank you
Regards.
Anwar
I can't remember who had that chart of the ratios...was it johnceggelston?
his part number TZ102YBABA-CF is a a little different from most i've seen. the 'y' is new to me. legacys (90-98) with AWD, all have a nother 'z' there. maybe because it's from an impreza.?
there is an end wrench article telling how to check the front and rear diffs to make sure they match. generally it says to put one side of the car on jackstands, unplug the trans wirring connector, this locks the AWD unit in 4WD, and start the car in neutral, brake off. now with the AWD unit 'locked', if you turn the rear wheels , the front should match them turn for turn. if they don't the diffs don't match.
http://endwrench.com/images/pdfs/CorrectInfo.pdf
if it's really an american car, i thought the 99-00 impreza and the 99-oo 2.2L legacy used the same trans, part number any way. a 96 outback should be a 4.44 final drive. my guess is that the 00 2.2L impreza is 4.11. just this week some one posted a hard to read list of info for trans and final drives, all of them, and i can't find it. it was on legacycentral i think. i'll look again.
found it: it's hard ot read but .... according to this thread, '00 imp 2.2L is 4.11, and 2.5L is 4.44
http://bbs.legacycentral.org/viewtopic.php?t=13500&sid=7add370daf15909c801cba58%20f69c2cbd
the tranny chart is just for manual trasnsmissions. it's ok to bookmark both of these.:)
http://www.northursalia.com/techdocs/trannychart/trannychart.pdf
i'd start counting the revolutions like i mentioned earlier. or try the tip above about locking the transfer clutches. do not wait for trans info, like i said, i've seen it time and time again and it's very difficult to get exact ratios on the automatics.
i'm surprised that after all of these issues you haven't just gotten the exact right transmission. for the cost of 5 transmissions and all that work it seems like you could buy whatever you want.
another easy way out of this mess is to swap to a manual transmission. then you have no electronics or TCU's to deal with.
