EA-81 type ASV plumbing, Pics needed
Need some good pics of the DS ASV plumbing. Mainly, from the valve up to the air cleaner can. The '85 BRAT has the one on the DS plugged off at the small exhaust tube fitting, valve and associated plumbing is gone. I have replacement parts, just not sure how it all goes together. Pics I have aren't clear enough on what goes where. Thanks
You shouldn't need it - they just end up failing and sucking plastic into the carb. If you are concerned about emissions police.... don't worry it will pass without it. I've ran numbers with and without and the difference is negligable.
