November 5, 200718 yr I have a 91 Legacy LS that gets a backfire through the intake. any ideas would be greatly appreciated i know plugs got about 10k on them. Factory wires have unknown mileage. There is no check engine light on so im not sure where to look first.
November 5, 200718 yr Author if i were to give the car a tuneup would ngk wires from advance auto be suitable for the car. i know i read oem or magncor but i beleive ngk is what oem are
November 6, 200718 yr I have a 91 Legacy LS that gets a backfire through the intake.[...] Under what conditions; starting, idling, constant load, accelerating, decelerating, etc.? Does gas tank level make a difference? Is the air filter relatively clean (aside from any scorching )?
November 6, 200718 yr Author Under what conditions; starting, idling, constant load, accelerating, decelerating, etc.? Does gas tank level make a difference? Is the air filter relatively clean (aside from any scorching )? it only does it under acceration. air filter is brand new. also has new fuel filter on. tank level makes no difference.
November 6, 200718 yr Author Other than backfire, does it bog/hesitate when accelerated? yea blogs and hesitates then it will backfire sometimes
November 6, 200718 yr Sounds like the mixture is a bit too lean. How many miles on the car? Ever replace an O2 sensor, and if so, at what mileage?
November 6, 200718 yr Author Sounds like the mixture is a bit too lean. How many miles on the car? Ever replace an O2 sensor, and if so, at what mileage? 150k i have not changed the O2 sensor since i got the car had it since 138k
November 6, 200718 yr We had a BRAT that did this. Don't know what it was; we sold it (had bought new in '78? and used as a farm pickup). Be interested to hear what you find. I later wondered whether the BRAT was a mechanical timing issue?
November 6, 200718 yr 150k i have not changed the O2 sensor since i got the car had it since 138k Tune the car up with new plugs, wires, and an 02 sensor. My money is on that correcting the problem.
November 6, 200718 yr Author Id definitely check out the wires. thats what im sort of leaning towards myself since im not sure how long they have been on. The oem wire are ngk correct?
November 6, 200718 yr I usually just get them from my dealer so I am not to sure.I would think so since the spark plugs are NGK as well.
November 6, 200718 yr Author I usually just get them from my dealer so I am not to sure.I would think so since the spark plugs are NGK as well. Ill try the plugs and wires and see if that helps will prolly be a few days till i get them. any reconmendations on plugs? i like running ngk but is there a certain one thats better to run.
November 6, 200718 yr Sounds like a timing issue. I would recommend taking a look at your crank pully to see if the bolt has come loose causing damage to the timing belt drive sproket and key.
November 7, 200718 yr Even if the crank pulley bolt is tight, it's possible that the t-belt may have jumped a tooth. It could be useful to determine when the belt was last replaced; is any of the service history before 138k miles known? Perhaps some testing with a vacuum gauge might help point to a possible cause.
November 7, 200718 yr My 2000 OBW backfired so badly that it popped the clips on the air filter housing. Changed plugs and wires and air filter and the problem immediately went away.
November 7, 200718 yr Author Even if the crank pulley bolt is tight, it's possible that the t-belt may have jumped a tooth. It could be useful to determine when the belt was last replaced; is any of the service history before 138k miles known? Perhaps some testing with a vacuum gauge might help point to a possible cause. no service history is known before 138k. i purchased wires and plugs today will put them in tomorrow and post results if any.
November 7, 200718 yr no service history is known before 138k. i purchased wires and plugs today will put them in tomorrow and post results if any. Can't a lean mix be caused by vacuum leak? look closely athe the bottom connection of the rubber boot connecting to the throttle body. Mine was caught enough to possibly leak.
November 7, 200718 yr Author Replaced plugs and wires today. So far its running good. Find out more once i get some more miles on it.
November 11, 200718 yr Author Drove the car some more and the problem still exist now i get the check engine light but goes off b4 i get a chance to pull the code. Im thinking that the mas is going bad.
November 12, 200718 yr There will be a code stored in the memory. CEL need not be on to pull codes. MAF's do go bad but are not a common failure.
November 12, 200718 yr Author There will be a code stored in the memory. CEL need not be on to pull codes. MAF's do go bad but are not a common failure. ill see if i can pull a code and report back
