Where is the ebrake switch?
Check the level of fluid in the
master cylinder.
As the pads ware, the fluid level drops because the pistons
move out.
The brake light will come on to warn you
of worn pads, it can come and go if the level is marginal.
If it's low and you simply fill it.
When you do change pads it will over flow
and take some paint with it.
Also the smal float in the MC can stick.
Wiggle it with a small screw driver to free it.
If it is the Ebrake switch,
I believe it's under your center console.
Pushing the handle down should cause it to go off.
Hope this helps.
"But odds are the diaphram in the cap needs to be pushed back in".
I don't know where Nipper is going with this but
some people may read it as the switch is located under
said diaphram.
(The one under the master cyl cap)
Although some older Subies did have the switch in the cap,
in my Legacys the switch is located in the bottom of
the master cyl.
It is a magnetic reed switch.
A small magnet located in a white
float turns the switch on when the fluid is low.
The magnet pulls the reed switch closed.
I have had this float stick in it's well.
Turns out the fluid was low, which explains why sometimes the switch would turn off going down hill.
Kinda irks me because I had a shop repair a line and bleed the brakes when they did the alignment. Gonna have to have them do it again. It's too cold to work in my driveway now.
