November 28, 200718 yr My dash lights are not working. I removed this black box that was in where my radio goes im not sure if this has anything to do with it. Also my power mirrors are not working Thanks Jason
November 28, 200718 yr Author Did you check the fuse? Were there wires hooked to the black box? Yes there were aires going to the box. Im not sure why i cut the wires to it. The fuses are fine
November 28, 200718 yr Yes there were aires going to the box. Im not sure why i cut the wires to it. The fuses are fine Hook it back up and see what happens. If they worked before you cut the wires to the black box and see if the dash lights come back on. You didn't cut any other wires under there, did ya?
November 28, 200718 yr Author Hook it back up and see what happens. If they worked before you cut the wires to the black box and see if the dash lights come back on. You didn't cut any other wires under there, did ya? I got it figured out. the fuses were blown. I checked the fuses on one of my other cars that are the same.
