December 17, 200718 yr My 99 Forester's ABS hadn't worked for about a year untill yesterday. It started working after I pulled the fuse and put the fuse back in. Today ABS is not working again. The abs light is not on. Any thoughts?
December 17, 200718 yr A bad relay ? Does the ABS light work? How can you tell its not working? nipper
December 17, 200718 yr A bad relay ? Does the ABS light work? How can you tell its not working?Indeed, does the ABS light come on at all? I refer back to:http://www.ultimatesubaru.org/forum/showthread.php?t=75545&page=2
December 17, 200718 yr Author Indeed, does the ABS light come on at all? I refer back to:http://www.ultimatesubaru.org/forum/showthread.php?t=75545&page=2 NO, never has.
December 17, 200718 yr NO, never has.You need to find out why, and take care of it. Once the bulb is working, it should be possible to retrieve trouble codes that can help with further diagnosis.
