December 20, 200718 yr is there any upgrades for the bottom end of a 2.2 such has the cams/crank and so on. if so where? any links? thanx
December 20, 200718 yr Cams I would suggest checking out delta cams that do regrinds. They do some good work. There is quite a bit you can do to those motors you will have to look on some of the impreza boards or legacy boards to learn more most likely.
December 20, 200718 yr Yes there was just a big write up on delta cams in subiesport or sport compact car I think it was last issue. http://www.deltacam.com/
