January 12, 200818 yr I have a 1988 Justy. The starter just went out. Will another Subaru model fit? Also, any recommendations on where to get a starter for a reasonable price? I live very rural and there are no junk yards around.
January 12, 200818 yr I have a 1988 Justy. The starter just went out. Will another Subaru model fit? Also, any recommendations on where to get a starter for a reasonable price? I live very rural and there are no junk yards around. Why do you think the starter is out? Are you getting a "click" when you turn the key? It could be that you have the classic ignition switch fault. The switch won't send enough power through(can't conduct the amps) to the starter solenoid. Try using a remote start switch connected to the solenoid. Or just simply jumper a wire to the solenoid. either way, if the starter then spins, you have a switch issue. This type of failure happens 10 to 1 over actual starter failure with Subarus. I've personally never had to replace an OEM starter. But I've seen more than a dozen ignition switch failures in Subies (and Hondas and Toyotas, which share switch suppliers) My solution is apushbutton starter switch, wired to fused constant 12v. Others use a relay, sometimes in conjunction with a pushbutton. I'd at least investigate the possibility before buying a new starter. You could end up with the same problem with the new starter.
January 12, 200818 yr Here is a great site if you have not found them already http://subarujusty.proboards20.com/
January 16, 200818 yr Author Thanks for the tip Gloyale. There is no click, nothing. It was starting but every 3rd or 4th try, it would do nothing. No click, nothing. I would do the old smack the starter trick and then it would start. Now that doesn't work and it does nothing when the key is turned. When this all started, sometimes the starter would turn slowly, like the battery was drained. The battery is fine as it's almost new and checks out fine. Other times it would start fine until now where I get no click or anything. Just in case, I tried jumping it but no dice.
January 16, 200818 yr sounds like the starter solenoid contacts want replaced. We don't see may Justys but if it has the same set up as our cars, it's a pretty common problem. You can change them if you are so inclined.
