What controls memmory of the Trip?
Somthing really weird happened and It had to happen within the last time I fillled up. The constant power for my TRIP memory doesnt work. Now everytime I shut off the eng it resets. Bad Cluster? Its an ea82 Digi dash.
Thanks in advance
Jess
Thanks in advance
Jess
might be that your battery is giving it last breaths of life better hurry up and perform CPR!!! j/k. but seriously i had that exact same problem with my GL-10 and i bought a new battery for it and problem solved.
Check under the dash, there is a fuse under there that is the keepalive memory power supply wire for the dash, they were disconnected at the factory so the batteries didn't die on the way over, and connected at the dealership before delivery, it's possible it's corroded or something and not sending power to the dash.
Thanks guys. it only did it for a few days, now it seems to be working? It has been 20ish at night but batt still holds a solid 12.5. I'm thinking loose connection maybe at that fuse? Hmmm
Jess
  • 5 weeks later...
Bump
Works a day or so, then out of no where clears it self? Any Ideas? I had pulled the dash to swap the heater core, I really didnt think I missed any plugs?
The *fuse* mentioned is not actually a fuse. It's just a connector. You'll probably have to drop the fuse panel to see it.
Way up under the dash, on the far drivers side i a blue single pole connector taped to the harness. Make sure the 2 ends of it are connected.
Sweet. Is this a constant power for the memory?
The reason I ask is it functions just doenst ALWAYS hold memory? If there were a loose connection it would also act this way. Ill try to finagle my hand up there to chech.
Thanks soo much!
Jess
