February 5, 200818 yr Hi All; Had engine out to repair valve damage from broken timing belt and think I may have wired injectors wrong. How can you tell if they are wired correctly? thanks in advance; Wayneb
February 5, 200818 yr There should be white tape around one from each side, I believe those go towards the front of the car. The other two will have a black marking on them.
February 5, 200818 yr The identifying tape is normally around the harness right at each injector connector; it's white on the front cylinders (#1 and #2), and black at the rears (#3 and #4).
February 6, 200818 yr Author Thanks Guys! Had them reversed on both sides! Explains a lot about how it's running! Thanks again; Wayneb
