wayneb Posted February 5, 2008 Share Posted February 5, 2008 Hi All; Had engine out to repair valve damage from broken timing belt and think I may have wired injectors wrong. How can you tell if they are wired correctly? thanks in advance; Wayneb Quote Link to comment Share on other sites More sharing options...
e4620 Posted February 5, 2008 Share Posted February 5, 2008 There should be white tape around one from each side, I believe those go towards the front of the car. The other two will have a black marking on them. Quote Link to comment Share on other sites More sharing options...
OB99W Posted February 5, 2008 Share Posted February 5, 2008 The identifying tape is normally around the harness right at each injector connector; it's white on the front cylinders (#1 and #2), and black at the rears (#3 and #4). Quote Link to comment Share on other sites More sharing options...
wayneb Posted February 6, 2008 Author Share Posted February 6, 2008 Thanks Guys! Had them reversed on both sides! Explains a lot about how it's running! Thanks again; Wayneb Quote Link to comment Share on other sites More sharing options...
