February 10, 200818 yr With A/C I have both an electric and an engine driven fan. I have an oil leak which appears to be from a front seal, and am hoping to do it myself. Haynes says to remove both fans prior to removing the radiator, but after removing the 4 nuts holding the engine fan to the water pump pulley I can't get the hub off. The 4 studs are about 3/16" too long for the fan to clear the radiator. I'm stuck here---any suggestions? Ray Mac
